2
This discussion topic has been answered Discussion topic: Itvx coronation street stream
This message was authored by: Graham4324
Got a weird problem with itvx. Usually watch Coronation Street using the app on sky q, I have an itvx subscription so avoid the adverts. Since Feb 5th no new episodes are appearing as available. If I sign out of the itvx app and then search all episodes are listed and I can stream them but with adverts. Have refreshed all apps still the same. Any ideas ?
Avatar for Graham4324
Level 2 icon
This message was authored by: Graham4324 Answer
Re: Itvx coronation street stream
Turns out it was finger trouble on my part as it appears that when you open an item that has multiple episodes on the My list section of itvx, it always shows the last episode you viewed and you have to left arrow to show ant hidden episodes that are available. Not sure I had to do that in the past as the latest episode used to always appear as the default. Oh well every day is a school day......
hi @Graham4324
I have just gone into ITVX on my box and it is showing episodes from 10/2 & 12/2 available under latest episodes - I haven't tried to watch as I don;t watch it
Perhaps try a full power down restart of your box.
Level 2 icon
Answered - Go to Answer
