Discussion topic: Issues with the hard drive
This message was authored by: Khudeja
We have been having issues with our hard disk drive it is
-not recording
-green light is not on
-It does not pause
-have to keep rebooting
-Error message - This service is not available because of a problem with your Hard Disk Drive
i want to discuss my plan I am very unhappy with this service being a customer of Sky for a long time now.
This message was authored by: Jones_The_Cat
Re: Issues with the hard drive
-not recording
-It does not pause
You need to give Sky a ring to discuss your subscription.
If you want to order a replacement Sky Q box you can do so here:
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/no-power-q-box/article...
-not recording
-It does not pause
@Khudeja as it appears you are having problems with your hard drive follow the link below which takes you through a few options on trying to fix the hard drive problem but if these dont work it allows you to order a replacement box
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Khudeja
Can you please provide the best number to call.
@Khudeja If you follow the link I posted it should lead you to ordering a new box but if you feel the need to call Sky
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
@Khudeja
If you definitely need to contact Sky, then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
