06 Apr 2023 07:37 PM
For the last couple of weeks certain sport channels are not working
06 Apr 2023 07:42 PM - last edited: 06 Apr 2023 07:42 PM
Hi @Ash+Mahon
What exactly Is the issue with the channels?
06 Apr 2023 07:54 PM
Channel 404, 406 and 407 doesn't have a signal but the rest are ok
06 Apr 2023 07:55 PM - last edited: 06 Apr 2023 07:56 PM
Hi @Ash+Mahon
If the issues continues maybe best to contact Sky for an Engineer to check your Dish alignment
