Discussion topic: Issues with signal
Message posted on 06 Oct 2023 06:17 PM
Issues with signal
No signal
Message posted on 06 Oct 2023 06:21 PM
Re: Issues with signal
@Ruth661 wrote:
No signal
Hi @Ruth661
You need to differentiate between No signal and no Satellite Signal .
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Message posted on 06 Oct 2023 06:32 PM
As @oldfella indicates no signal or no satellite signal are different. ”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
