Discussion topic: Issues with mini box
Message posted on 09 Jul 2023 07:54 PM
Mini box not working
Message posted on 09 Jul 2023 07:58 PM
Re: Issues with mini box
Hi @Oakley1965
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 09 Jul 2023 07:59 PM
Tried all this as am tech trained
Message posted on 09 Jul 2023 08:02 PM - last edited: 09 Jul 2023 08:03 PM
@Oakley1965 Your other threads have been removed as you have this one active.
Message posted on 09 Jul 2023 08:09 PM
This has still not worked
