Discussion topic: Issues with connectivity on q mini
This message was authored by Deedee64 This message was authored by: Deedee64
My main Q box remote has partially stopped working ie some buttons don't work, and one of my mini boxes very often has connectivity issues (MR204)
This message was authored by Quoman7 This message was authored by: Quoman7
Re: Issues with connectivity on q mini
Hi @Deedee64 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back ont, then do the same with any Mini boxes?
If you are still having problems with your remote buttons then, with a slighly damp cloth wipe over all of the buttons including the SKY logo button at the top of the remote, to free up any sticking buttons?
Deedee64
Is this supposed to fix problem as it keeps happening. Its very annoying when your watching a programme (live or recorded) and you have to do this quite regularly. I'm finding Q absolutely useless.
Hi @Deedee64
Regarding the mini connectivity try a Network reset on the mini.
Deedee64
Sky sent guy to fix problem on Wednesday, gave me new box. Worked OK but tonight it's gone and lost all apps and when I tried to reset my remote stopped working the box.
