Discussion topic: I recently changed my package and now my tv is t working
This message was authored by: Dan63
I recently changed my tv package got sent a new router but no new tv box and now iv setup my new router my tv isn't working what do I do?
Re: I recently changed my package and now my tv is t working
Assume this is your main Sky Q box.
Did you make any significant change to the TV service?
