Discussion topic: Issues watching recordings
This message was authored by: Jo-AnneN
When watching a recording screen goes blue and says 'channel not available' if i exit then go back in it plays agin but it doing it about 6 times during a half hour programm
Last night it did it after i paused live TV too
Any idea's ?  is the hard drive failing ?
Re: Issues watching recordings
Hi @Jo-AnneN
Try a Reset Settings in the Q box hidden menu.  It may help.
If you do have a hard drive issue you will normally get a hard drive error message.
Avatar for Jo-AnneN
Thanks,  I wil try that
Avatar for Jo-AnneN
That didn't work the message ssys
'Thier is a  technical issue with this channel" when I play something recorded
