Discussion topic: We had to reboot the fibre
Message posted on 04 Jul 2023 05:01 PM
since rebooting the w box will not connect
Message posted on 04 Jul 2023 05:12 PM
Re: We had to reboot the fibre
Hi @Beckyfox15
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
