Discussion topic: Issue with minibox
This message was authored by: Ali5588
Issue with minibox
Hello I have recently added a second minibox and is not working. On the additional screens it states that there are too many miniboxes connected.
Re: Issue with minibox
@Ali5588
Which main box do you have? Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
