Discussion topic: Is there a quick way to empty the deleted folder on sky a box
Message posted on 16 Apr 2024 08:03 PM
How do you clear the recorded programmes after you deleted them
Message posted on 16 Apr 2024 08:12 PM - last edited: 16 Apr 2024 08:13 PM
Re: Is there a quick way to empty the deleted folder on sky a box
You don't need to. The box will reclaim the disk space from deleted programmes as/when it needs to.
Message posted on 16 Apr 2024 08:13 PM
Only one at a time unfortunately @Gaz4jane
(In Recordings - Manage - Deleted).
If you want to keep the Deleted section empty then it's best to do this on a regular basis.
Here I go into the section before I shut down in the evening and Delete forever everything deleted that day.
Is not necessary to do as Sky Q housekeeping will start deleting content ftom this section first if more space is needed.
