Discussion topic: Is the Sky Mini Box really so poor ?
Message posted on 10 Sep 2024 05:39 PM
I know the mini box is really a absolutley poorly designed piece of equipment that really isn't fit for purpose, let alone being charged for.
I'm getting to the point that its virtually daily that I have to unplug the box to reboot it to work.
Anyone else have this issue ? Or am I missing something in the settings that may be causing this ?
Cheers.
Message posted on 10 Sep 2024 05:51 PM
Re: Is the Sky Mini Box really so poor ?
Have you spoken to Sky about it? I didn't have that problem with my Mini boxes.
Message posted on 11 Sep 2024 02:55 PM - last edited: 11 Sep 2024 02:55 PM
Mini boxes have been around for eight years now: there are millions in daily use.
Typically the first suspect is always an inadequate wireless connection from the main Q box, which Sky will attempt to resolve through loaning a WiFi booster.
Message posted on 11 Sep 2024 05:47 PM
Cheers all,
I have the mini box connected to an ethernet cable as the sky wifi is not strong enough for it to connect.
I just get a blank screen with the green light on, hence having to unplug it. Its new box as well, had it replaceed last week and getting same issue.
Message posted on 11 Sep 2024 07:01 PM
That would strongly suggest the issue is elsewhere.
Is the WiFi switched off on the Mini box?
Is it a managed or unmanaged switch?
What is the ISP and router in use?
Message posted on 12 Sep 2024 03:07 PM
The wifi isn't the issue, its the fact the box fails to start. I'm on sky fibre but can't wait to get back to virgin in truth, not been impressed with it.
It's if it's stuck in standby but the green light is on to say the box is active. Reboot the box its fine, but can only do that via unplugging it.
