Discussion topic: Internet problems
This message was authored by: Marcie1
Internet problems
My sky box won't connect to the internet
Re: Internet problems
Hi @Marcie1
Assume this is your main Q box.   If it is have you tried a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
