Discussion topic: Internet keeps loosjng connection
Message posted on 22 Sep 2025 05:29 PM
We are trying to connect our main sky box to the Internet. No problem connecting the TV but the connection keeps dropping from box. We've tried boosters routers etc.
Message posted on 22 Sep 2025 06:15 PM
Re: Internet keeps loosjng connection
Hi @TRIONA
Sky Q will not connect by WiFi to 3rd party boosters.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 22 Sep 2025 08:48 PM
It connects without any problem. After a minute of connection the connection drops
Message posted on 22 Sep 2025 08:53 PM
Message posted on 23 Sep 2025 08:29 AM - last edited: 23 Sep 2025 08:31 AM
It will connect to 3rd party boosters / meshes over 2.4GHz.
But a mini won't use them to connect to the Q.
And also it will be horribly flakey as you've discovered. Try hardwiring the Q into a booster if it has an ethernet port, and piggybacking its wifi connection to the router.
If that's no good, also worth trying disabling 5GHz on the wifi network. It seems to confuse the simpleton Q box.
