Discussion topic: Internet dropped out
This message was authored by: RedSquirrel05
My Sky Q tells me it has no internet connection, but when I go to set up, the internet connection is working ok
Re: Internet dropped out
Hi @RedSquirrel05
Try first rebooting your Router by disconnecting the power lead for 30 sec and then reconnecting.
Wait until the router is completely back up and running and then reboot the main Q box.
Avatar for RedSquirrel05
Hi oldfella
I do not remember how many times that I have done this and I still constantly lose internet connection.
I do not work for sky, I only pay for a service which is not working. The excuses that I receive from the service engineers are many and mostly unbelievable..
Too much power on the PoE from my switch. ( my switch does not have PoE facilities).
The Internet is the problem, get it fixed.
my switch was faulty, so I changed it, no difference.
The sky box can not understand the router that I have, so I have to change my router.
The colour code on my RJ45 lead are not right., even though they are the same at both ends.
The twists in my RJ45 cable are not correct so this is interfering with the data.
My Ping is too slow. (I am a gamer so I know that there is no problem with my Ping or speed.)
etc.et.,.
I do not want a refund, I just want the thing to work, after 3 years I am starting to lose the will to live.
RedSquirrel05
