Discussion topic: Intermittent picture blurs
Message posted on 20 Apr 2024 03:37 PM
Hi
After a few hours of my sky Q box being on, the picture becomes juddery for a few seconds, then goes normal for a few seconds, then blurry again. It's been going on for a few weeks and is now getting worse. It's on all the sky channels and apps but screen mirroring is fine.
We've turned everything off and on a few time but nothing seems to work.
Any ideas? - thanks.
Message posted on 20 Apr 2024 03:43 PM
Re: Intermittent picture blurs
@Aerobimum wrote:
Hi
Hi @Aerobimum
Try a Reset Settings in the Q box hidden menu. See if that helps
Message posted on 20 Apr 2024 08:38 PM
Thanks so much! This seems to have worked! So far so good! 😀
Message posted on 23 Apr 2024 08:10 PM
Help! This worked for 24hrs - thrn thr wobble came back! Should i do another reset - or is there something else i should try? Thank you.
