Discussion topic: Intermittent connectivity issues between Mini box and Sky Q
This message was authored by: KellyW1979
For over a week now my Mini box is persistently losing connection to my Sky Q
Re: Intermittent connectivity issues between Mini box and Sky Q
Hi @KellyW1979
Reboot the mini as above.
This message was authored by: SMisra
After struggling for months, if not years, with connectivity issues between the Sky Q Mini and Main boxes, I have finally managed to setup a stable and reliable solution. I live in a townhouse separated by concrete floors, so had issues in getting my WiFi signal reliably as well across all floors. Combine that with a busy London neighbourhood with too many WiFi routers and channels in use, I think signal clashing was and is a big problem. I had to go for a Mesh WiFi system - Linksys Velop in my case, with several nodes spread across the house. The Mesh nodes do result in a loss of speed, with none of the satellites able to serve anything better than 70 to 80 Mb, but the coverage is reliable and good - most of the time.
Sky Q also uses a mesh but channels and frequency are very limited, so the mesh is unable to self-correct. In my case, I had the Sky Q main box, 2 Sky Q mini boxes, and a Sky Q extender. I tried all options and had the Sky engineer in as well multiple times to resolve the daily multiple dropouts between the Main and Mini boxes. Frustratingly, the mini would return the status of being connected to the main box (both Sky Q and WiFi) but still show the 'No connection' error on the screen. I don't need to tell you how amazingly frustrating it has all been as you're likely facing the same problem if you're reading this article. No amount of fiddling - with power saving settings, wifi channels etc. was able to solve the problem.
The solution for me was connecting every Sky Q box, main and minis, via Ethernet cable to a Velop node, and disabling completely (via 001 Settings advanced options) the wifi signal of Sky Q - so basically making Sky Q believe it's communicating via Ethernet with each other and the Sky Q wifi mesh is disabled. This has worked like a dream - connection dropouts are gone, the setup is simple, and the lack of Sky Q mesh has reduced the signal collision at home and made my Velop mesh also more reliable. It's Nirvana!!
This message was authored by: veryangry
We had a power cut at the weekend & now I have the same problem. How do we get an engineer to attend. It is truly pathetic.
@veryangry have you tried what @oldfella suggested
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
I am reasonably tech savvy. I have wasted 4 hours on trying everything. It needs an engineer’s expertise to solve. We have thick walls etc & the set up by an engineer was tricky in the first place. It took me 2 hours on a call with a Sky adviser to convince him to get an engineer to call in the first place about 18 months ago.
I will try contact tomorrow - so thanks for that info.
This message was authored by: CraigSt
I've had the same SkyQ mini box issues for weeks now. Sky engineers have been here 3 times, swapped the main Sky Q box, added 2 repeaters and I still get the mini boxes loosing connection. I use Virgin fibre broadband as I can't get Sky fibre into my house. Nothing has changed in my setup and when the Sky boxes fail all phones, pcs etc still remain connected and working. Reaching the end of my tether here, if this can't be fixed I'll be sending it all back.
Re: Intermittent issue with connection between mini box and sky q box
So, I have the same problem and do you think it's a good solution having to unplug and reboot my Sky Q and Sky Q mini boxes sometimes multiple times a night?
There has to be a workable solution to this problem.
This message was authored by: ftballman
What worries me most about that is the multiple visits without fixing it. I'm basically repeating myself in a lot of these mini box threads but have a look at powerline adaptors.
From experience and general reading here, main to mini over sky's own mesh is ok in perfect circumstances. But with so many different set ups, broadband, construction differences, the only reliable connections are wired ( ethernet from box to box or box to router to box). Most people won't have or be able to run cables over those distances so powerline might be able to resolve that ( again distances and home wiring may be an issue).
This message was authored by: rpjray
Sky engineer cured problem. Stated that previous engineers had not installed equipment correctly.
