Discussion topic: Need to move to stream as new flat can't set up sky q
Message posted on 20 May 2024 02:06 PM
Hi all,
Just moved and been with sky 16 years but now I can't get sky Q. I now have to get a puck and streaming contract.
Anyone else went through this? What was the outcome? More/less expensive?
Message posted on 20 May 2024 02:31 PM
Re: Need to move to stream as new flat can't set up sky q
@Christina28 Give Sky a call they can sort this out for you, any deals are always customer specific, what one customer may get another won't.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 20 May 2024 02:39 PM
@Christina28 wrote:Hi all,
The cost of Sky Stream is largely dependent on what you watch. The key thing about it is that it is very different to Sky Q and relies entirely on you having a fast and stable broadband connection (at additional cost, but does not need to be with Sky). It also does not record programmes in the same way as Q so you need to be willing to accept on demand streaming of programmes, rather than playing back of recordings.
Sky Stream has the benefit of offering UHD & Atmos on multiple pucks at the same time (bandwidth allowing) if you have multiple 4K TVs with appropriate sound decoding devices attached, but this requires the Whole Home subscription at additional cost.
If you like fast forwarding through ads on recordings from Sky Q then you will need the ad-skipping pack on Sky Stream (at additional cost).
If you are currently out of contract on Sky Q then the overall cost of Stream could well be lower, but pricing does vary. If you are still in contract on Q then you'll need to ring Sky to discuss your options.
