Discussion topic: Interference when using my iPhone 15
Message posted on 18 Jan 2025 02:08 PM
When making a call on my iPhone 15 I experience interference on my Sky Q picture on the TV connected to the main box. I have tried using a new HDMI cable but this has had no impact. Any suggestions appreciated. Thank you.
Message posted on 18 Jan 2025 07:10 PM - last edited: 18 Jan 2025 08:46 PM
Re: Interference when using my iPhone 15
Satellite or streaming content?
do you have wifi calling turned on? Assuming this is a voice call via your mobile carrier and not facetime / whatsapp
Message posted on 18 Jan 2025 08:34 PM
It's Sattelite and the calls are made via the O2 network
Message posted on 18 Jan 2025 08:38 PM
Wi-fi calling is switched off
Message posted on 18 Jan 2025 08:59 PM
Bizarre. never had an issue (mix of iphones from 12 to 15 here, all on O2 but I think we all have wifi calling on and there's also no 5G) Suggests maybe a cable shielding issue. I wonder if the frequencies of the mobile network and satellite channels interfere somehow.
For a bit of diagnosis, could turn off 5G on the handset
maybe try turning on wifi calling too
if you play something stored on the hard drive does it happen?
Message posted on 20 Jan 2025 09:13 PM
As per your suggestion, when the issue occurred this evening, I started to watch a recorded program and there was no issue. I also tried changing the sky channel and the issue was not present. It appears to be specific to channel 109 U & Allibi HD.
Message posted on 20 Jan 2025 09:19 PM - last edited: 20 Jan 2025 09:27 PM
@SteveeW U&Alibi are in Frequency 12363V other channels here are Nickelodeon UK And Ch4 South East & Channel 4 Scotland, if you have access to one of these other channel it's worth checking if those are affected.
If so are we maybe looking at a Local Oscilator frequency issue interference through the satellite cable?
Message posted on 20 Jan 2025 09:33 PM
I have just checked Channel 4 and it's the exactly the same issue.
Should I give Sky a call?
Message posted on 21 Jan 2025 08:27 AM
One 5G band uses 24GHz to 40GHz
It could be some kind of interference caused by some harmonic transmissions being exactly double the 12.363GHz of that band
if you call with 5G disabled, I assume it resolves it?
Message posted on 21 Jan 2025 10:11 AM
5G isn't used for calls on O2.
Will using 5G affect quality of voice calls?
No – 5G is a data service only and therefore won't impact calls. If you're connected to 5G and make/receive a call, your phone will automatically switch to 4G. For better call quality, you can always enable Wifi and 4G Calling if your phone supports these features.
https://www.o2.co.uk/help/network-coverage-and-international/5g-setup
Message posted on 21 Jan 2025 01:51 PM
Oho!
Did not know that. Ok then I have no idea.
Message posted on 21 Jan 2025 05:59 PM
@SteveeW I'm tagging a resident expert on satellite setups @Godfrey who may be able to offer some insight.
