2
This discussion topic has been answered Discussion topic: Interference on screen from satellite not transmitting properly
This message was authored by: Matt250861
Interference continuous on screen interrupting program watching. Programmes are paused resulting in missing programme conversations and visual missing.
Re: Interference on screen from satellite not transmitting properly
@Matt250861
The satellite will be transmitting fine otherwise millions of customers would be affected. If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@Matt250861
@Matt250861
As @Daniel0210 indicates, transmission  affects all satellite television viewers, and something like fifteen million households use broadcast Sky (and Freesat) which would make this forum rather busy in such an event.
An individual reception problem is rather more likely, with the most likely suspect being dish alignment, followed by cabling and then LNB faults.
