Discussion topic: Installation
This message was authored by: Nancy85
Message posted on 01 Aug 2023 01:59 PM
Installation
The engineer arrived and did not set up the TV because of the building connections are different from the ones that sky uses.
This message was authored by: SlenderRobert
Message posted on 01 Aug 2023 03:01 PM
Re: Installation
@Nancy85 wrote:The engineer arrived and did not set up the TV because of the building connections are different from the ones that sky uses.
You would need to check with whoever manages your building as to what system they use, then get back in touch with Sky to see what options are available.
