Discussion topic: Insert Viewer Card Error Message
Message posted on 14 Dec 2025 08:32 AM
Sky Q box not working this morning. It says I need to insert the viewing card. This is already in, I have tried unplugging the box and plugging back in, taking the card out and putting back in. Also into settings and set up viewing card. None of these have worked. Does anyone have any other suggestions? Thanks.
Message posted on 14 Dec 2025 12:06 PM
Re: Insert Viewer Card Error Message
@Mikeb881 when you took the card out and put it back in did you give the chip on the card a wipe with a soft dry lint free cloth if not could try that
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Dec 2025 12:09 PM
Hi thanks for your reply. Yes I did try that, but still didn't work unfortunately.
Message posted on 14 Dec 2025 02:54 PM
@Mikeb881 In that case i think you atre going to have to give Sky a call
