Discussion topic: Incomplete recordings
This message was authored by: Vics2
My Sky Q box finishes recording a programme at exactly 3 hours and 33 minutes. Why is this and how can i correct the fault/
Re: Incomplete recordings
@Vics2
If you are new to the forum or this is your first post then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
You haven't said how long the programme should have been?
What time of day?
How full is HD?  (It should auto delete but may not if items locked etc.)
This message was authored by: Invisiblename
If this was a programme that had delays in it, such as F1, then it is possible that it over-ran its  original ending time.  For anything that has the potential for an "overrun" it's always advisable to set the next programme to record as well.
I am just another Sky customer!
Avatar for Vics2
It's live sport so has a fairly open-ended time limit. I'm just thinking that, as it always stops at 3 hours and 33 minutes, it must be part of the settings.
Avatar for Vics2
I will try your suggestion this weekend.
Avatar for Vics2
HD is only 40% full so that shouldn't bethe problem. Recordings made in the evening.
