Discussion topic: Incompatible with Sony
Message posted on 05 Apr 2023 07:38 AM
Re: Incompatible with Sony
Any idea what the resolution is?
Message posted on 05 Apr 2023 08:53 AM
@tom-jerry1971 well I hope that after providing details @Chodley will look into it and provide us with some solution
Message posted on 05 Apr 2023 09:11 AM
@DJMM1 wrote:Ok
TV randomly restarts from time to time. There is no pattern to it. However, it tends to happen more often shortly after turning Sky box and TV on.
The audio stops first then the second later TV restarts.
Two things.
Just to clarify, does this only happen when your Sky Q box is on.
In what order do you turn the TV and Sky Q box on or are you using the Sky Q box to turn the TV on (via the HDMI control = on in Sky Q settings)..
Can you please let us know your Sony TV software version?
I will flag your post to Sky through our closed forum to see if they can offer any more help/insight.
Message posted on 05 Apr 2023 09:42 AM
@lettice wrote:Just to clarify, does this only happen when your Sky Q box is on
Yes.
I'm using SkyQ remote to turn on both the TV and the box - I'm pretty sure it is done via SkyQ settings - it's been setup by Sky during installation. It allows me to control the volume and I can turn on and off TV all using SkyQ remote.
To turn it all on all I need to do is press Sky button.
To turn off the TV i need to hold the "power" button on SkyQ remote for few seconds
I'm not sure if this is the correct thing under device preferences -> about it shows: Version 9 / Android security patch 5 Jan 2022 / Kernel Version 4.9.125
Thank you for looking into it!
Message posted on 05 Apr 2023 09:52 AM
@DJMM1
There is a firmware update 21st sept 2022 for your TV.
Drivers and Software updates for KD-43XF7596 | Sony UK
Firmware update to v6.7210 | Sony UK
It mentions;
- Resolves an issue where the TV randomly restarts
Might be worth trying to update your TV firmware.
Message posted on 05 Apr 2023 11:27 AM
@lettice Thank you. TV already has the latest firmware
Its runs software version PKG6.7210.0363EUA
Regardless, I've downloaded it to USB as per instructions on the page you have shared but the TV refuses to run it. There is a message popping out saying the software is up to date
Message posted on 05 Apr 2023 11:32 AM
@DJMM1 wrote:@lettice Thank you. TV already has the latest firmware
Ok, looks like you have latest firmware.
Will let you know here if we here anymore from Sky.
Message posted on 05 Apr 2023 01:41 PM - last edited: 05 Apr 2023 01:43 PM
@DJMM1 wrote:@tom-jerry1971 well I hope that after providing details @Chodley will look into it and provide us with some solution
I meant the community, not a personal SLA commitment 😉
There are a LOT of reports on the web of Sony TVs rebooting themselves. Suggestions include;
power downs for 60 seconds, holding remote power button whole you plug back in to do a soft reset
Turning off CEC
Factory reset
Removing batteries from the remote (???)
Personally 5 years sounds ripe for an upgrade, and to a Panasonic 😁
None of this Android complexity, and not data harvesting like Samsung & LG.
Message posted on 05 Apr 2023 01:49 PM
@DJMM1
Sky have asked me to pm you with something to try.
Look out for a PM.
Sky are also in contact with Sony to work with them on any resolution.
Message posted on 12 Apr 2023 11:10 AM
@DJMM1
Did the suggestion sent in the PM help at all with your problem?
Message posted on 12 Apr 2023 07:39 PM
It appears to solve the issue.
I've not had TV restart since disabling Samba
thank you!!!
Message posted on 14 Apr 2023 06:10 AM
A new thing for this is that the remote doesn't work until the TV switches itself off and does it's rejigging. Just now I couldn't alter the volume and the TV wasn't switching off so I had to switch off at the wall, which took forever. I want my old Sky box back!
Message posted on 14 Apr 2023 09:51 AM
@tom-jerry1971 wrote:A new thing for this is that the remote doesn't work until the TV switches itself off and does it's rejigging. Just now I couldn't alter the volume and the TV wasn't switching off so I had to switch off at the wall, which took forever. I want my old Sky box back!
Did you read the post immediately above yours?
Message posted on 15 Apr 2023 07:54 AM
The Samba thing is already switched off and the CEC thing, when I google the instructions on how to check this they don't follow. So if CEC is the resolution I have no idea how to do this as the selections don't tie in with my display. I've even looked on the Sony website.
Message posted on 15 Apr 2023 08:56 AM - last edited: 15 Apr 2023 10:30 AM
Its more about toggling the Samba option, than just switching it off.
