Discussion topic: Im now on my second replacement sky Q mini box and the sound is faulty again
This message was authored by: wtd240
The sound is completely fuzzy. Last time you guys sent a new sky q mini box. That worked for a while but now this one is not working either. My WiFi is 900mb direct fibre so there are no issues there. Can anyone help? It's driving me mad.
Re: Im now on my second replacement sky Q mini box and the sound is faulty again
@wtd240
That would rather point suspicion at the device which actually produces the sound...
Avatar for wtd240
Ok. I will switch it out and try different device but the DVD sound plays ok. Thank you.
Your WiFi isn't used for Q to Q wireless communication.  In fact it could actually be interfering.
Ensure your router's 5GHz channel is as high as possible to avoid clashing with ch 36-48 that Q uses by default.
