Discussion topic: ITVX Slow response
This message was authored by: PAUL4727
Re: ITVX Slow response
I have been frustrated with the speed of ITVX on sky Q for a number of months. Several people have told me that it is because ITVX is on a slow server.
I have since changed my television to a more up-to-date model and ITVX now works extremely well with the built-in Amazon fire. The speed of which the application loads is extremely quick together with the search facility.
This tells me that the problem lies with Sky Q and possibly software that is becoming old and needs to be updated. I hope this answers a number of questions that people have posted recently.
Paul Tyrrell
This message was authored by: ozsat
I've been using ITVX on several devices since it launched.
Amazon Firestick seems best overall - although a couple of devices still don't have the live channels.
Although SkyQ has the live channels - it's overall load and menu speeds are dire.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
ITVX is the worst app on Sky Q, it's very slow and clunky. Discovery+ is a close second.
The Sky Q system is coming up to a decade old now so a Fire Stick or similar device will always perform much better.
This message was authored by: AdrianLuton
The itvX app has been really slow since it launched on SkyQ.  It is slow on main box but on mini boxes its even slower.
As I test I compared the times between the two devices I mainly use - Amazon Firestick and SkyQ main box V2.
I select Buffy s1 e1 as the test programme as it came top of the menu list each time so I didn't even have to search around for it. Time stops at point play back starts.
I also did the test with ITVX on each device, then used the device for another app, then went back and retried ITVX again.
Results are:
Amazon: 1st time: 32 sec. 2nd time: 12 sec
SkyQ: 1st time: 55 sec. 2nd time: 55 sec.
It seems SkyQ takes forever to load the images before you can progress. So it may not be the app navigartion itself which is the issue, but the loading of images.
I except SkyQ is older and slower - but ITVX is an exception on SkyQ being far slower than anything else.
Couldn't resist a stopwatch test. 31seconds including an age warning (it wasn't Buffy, whatever came top on mine)
I think ITV X is just a bad app AppleTV+ takes 24s. Netflix about 15 if you have to pick profile, then ~8 the next time when it is still in RAM and knows who you are.
