Discussion topic: I want to get a SKY Q WITHOUT the BROADBAND installation....!!!
Message posted on 10 Jan 2024 12:46 AM
Right I WANT to register with SKY Q box without the BROADBAND installation...!!!
Message posted on 10 Jan 2024 05:59 AM
Re: I want to get a SKY Q WITHOUT the BROADBAND installation....!!!
What is stopping you from ordering just Sky Q, if you can't do it online then call Sky to get it placed.
You will need a broadband connection otherwise you will be limited to live TV without the use of catchup or boxset services or those from the likes of Amazon, Netflix etc...
Message posted on 10 Jan 2024 07:08 AM
Hi @K3vin1 Do you already have broadband? It is difficult to understand your question, do you mean have Sky Q without any broadband connection to the property.
Message posted on 10 Jan 2024 08:42 AM - last edited: 10 Jan 2024 08:44 AM
There's no requirement to add Sky Broadband to a Sky Q order, although Sky obviously encourages this.
Without any broadband at all, Q functionality is distinctly limited, and Sky installers have been known to decline putting the system in place where they think the customer doesn't understand this.
Internet access is needed during the initial set-up to activate the main Q box: this can be from a cellular hotspot.
Message posted on 10 Jan 2024 09:29 AM
@K3vin1 wrote:Right I WANT to register with SKY Q box without the BROADBAND installation...!!!
Were you stamping your feet at the same time as you typed that?? 😂
