Discussion topic: I need to change my LMB setting from Wideband to SCR to watch sky tv in my caravan
This message was authored by: Markpritchard
I have a Maxview Connect satalite dish on my caravan, it has a sky Q LMB fitted but the instructions are telling me I need to change the LMB settings on my Sky Q box from widenand to SCR but I'm having trouble changing the settings
This message was authored by: Godfrey
Re: I need to change my LMB setting from Wideband to SCR to watch sky tv in my caravan
@Markpritchard   to configure a Sky Q receiver to use SCR LNB mode;
Press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
Godfrey.
