Discussion topic: I need to book an engineer as you have identified Sky Q issue found
This message was authored by: Broadway1
I have gone through your information & you identified that Sky Q the was an issue found. I have have aerial engineers out and they informed me there was a network connection but no satellite signal.
Avatar for Broadway1
Level 0 icon
Re: I need to book an engineer as you have identified Sky Q issue found
How do I get this sorted. I need an engineer to come out
GB
@Broadway1
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
Hi @Broadway1   You cannot request an engineer here, you would need to contact Sky. Please Welcome below.
