Discussion topic: I keep getting a 'Mode Not Supported' message on screen. It then says 'Resolution not supported.
This message was authored by: jtk1
Message posted on 19 Jun 2023 12:31 PM
It says. Resolution not supported. Change the resolution of the external device.
Find out more
Message posted on 19 Jun 2023 12:35 PM
Re: I keep getting a 'Mode Not Supported' message on screen. It then says 'Resolution not supported.
Try Home 1 0 8 0 Home to reset Q resolution
Message posted on 19 Jun 2023 12:41 PM
Cheers, I'll try that.
