Discussion topic: I have 3 sky q mini boxes that are all saying no satalite signal
This message was authored by: Tony+mc21
I have 3 sky q mini boxes and they are all saying no satellite signal.
I have upgraded my broadband and the engineer is due 21st March will this have something to do with it
This message was authored by: Tom-W19
Re: I have 3 sky q mini boxes that are all saying no satalite signal
Hi @Tony+mc21
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
This message was authored by: Mr+Flibbles+86
We are still looking to help you @Tony+mc21. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Hi @Tony+mc21
Reboot the mini as above.  Start with the mini nearest to the main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.  Follow the same procedure for other mini.
