Discussion topic: I can’t get my sky Q box to connect to the braodband, I just need to speak to someone at sky for hel
This message was authored by: LJM01
  • Can anyone help please I can't get the sky box to connect to the broadband I've tried everything I can find on the site. It isn't recognising the password, WiFi is working as the phones and laptops will connect.
Re: I can’t get my sky Q box to connect to the braodband, I just need to speak to someone at sky for
Is it Sky broadband or someone else?
@LJM01 who is your broadband provider
Hi @LJM01
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for LJM01
It's Sky
Avatar for LJM01
I can't see a WPS on my router?
Avatar for LJM01
Sky broadband
It is there. Standard icon on the button.
