01 Jun 2023 10:04 AM
Hi I am unable to turn my sky box on
01 Jun 2023 10:06 AM
Posted by a Superuser, not a Sky employee. Find out more@Lizgage What's happening when you try to turn it on? Any messages? Any lights showing on the box?
01 Jun 2023 10:34 AM
@Lizgage wrote:Hi I am unable to turn my sky box on
@GD1 wrote:@Lizgage What's happening when you try to turn it on? Any messages? Any lights showing on the box?
I have started to get something similar also, every few months or so the box will fail to turn on; using the remote or the button on the box itself - it simply remains unresponsive.
The remote is fine as it turns the TV on & off etc. just no response at all from the Q box.
In order for me to get it to work, I've had to remove the power to the Q box for 30 seconds or so then plug it back in/restore the power. After that, no issues (for a few months)
01 Jun 2023 11:59 AM
Nothing happens light stays red I went on to speak to a human on the phone and went through all his suggestions and now have an engineer coming in 6 days time till then no sky
01 Jun 2023 12:06 PM
Hi @Lizgage
Have you tried switching the Q box on by pressing the Standby button on the front right of the Q box (the Amber Led)?
If this brings the box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
