Discussion topic: I am not getting any signal on my sky box
This message was authored by Raj1976 This message was authored by: Raj1976
I am not getting any signal on my sky box , can you send an engineer out asap to fix this problem, I have tried everything
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: I am not getting any signal on my sky box
@Raj1976
Firstly you're not talking to Sky Customer Services on here. This is a customer based forum where customers try to help other customers.
If a message is displaying ”No signal” it tends to be from your TV (in which case check the HDMI cable between the Sky Q box and your TV).
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
