4
This discussion topic has been answered Discussion topic: I Can’t see option or how to order additional (2nd) sky q mini box ?
This message was authored by: Cwmgweche
This message was authored by: bob1234 Answer
Re: I Can’t see option or how to order additional (2nd) sky q mini box ?
@CwmgwecheThere is an option in your on line account, not that easy to find but log in and look at "your products" and scroll down. Hopefully this link will take you there.
https://www.sky.com/hub/tv?dr=s
@Cwmgweche   Give Sky a call, you can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Avatar for Cwmgweche
Thanks @bob1234 for pointing me in the right direction !
That button didn't work in iPad app (errors when click on your products!) but worked for me from iPhone app and now all ordered.
thanks !
This message was authored by: stormy1954
This link worked for me
https://www.sky.com/mysky/tv/home-setup
