Discussion topic: How to move sky q box
This message was authored by: Paulneed1966
Hi I want to move sky q box into another room
Re: How to move sky q box
@Paulneed1966
If you mean you want the cables running from the dish into the dwelling moved you'll have to call Sky if you want them to do it. You could also get a quote from a local independent satellite company. A week before the Christmas holiday period may not be the best timing.
HAPPY NEW YEAR
Avatar for Paulneed1966
Re:move sky q box
Thanks for advice
I am struggling to find a contact number to get sky to do it. Any thoughts on a number
Re: Re:move sky q box
@Paulneed1966
If you definitely need to contact Sky, then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum.
Note: We’ve been informed the lines are busier than usual at the moment.
HAPPY NEW YEAR
Thanks for your help
