Discussion topic: How do i split screen sky Sports
Message posted on 03 Aug 2025 03:17 PM
How do I Split Screen Sky Sports for two different channels
Message posted on 03 Aug 2025 03:20 PM
Re: How do i split screen sky Sports
You can't. This was removed many years ago.
Message posted on 03 Aug 2025 03:23 PM
That's mad, why would they take that option away?
In this day and age that should be a fairly basic option to offer?
Message posted on 03 Aug 2025 03:25 PM
@Ryan027 Given the fact it's been removed a very long time ago and you've only just noticed strongly suggests it was rarely used by customers.
Message posted on 03 Aug 2025 03:28 PM
It wasn't used because I was told it was not an option that Sky offered so I did not try.
Somebody mentioned that they thought it was an option which I thought would be great, only to find out it isn't.
I would use it all the time if it was an option
Message posted on 03 Aug 2025 03:33 PM
It almost certainly won't be coming back after all this time bearing in mind the remaining limited life span of Sky Q.
Message posted on 03 Aug 2025 03:38 PM
@Ryan027 A solution is to use the sky sports app on a decent size tablet device (I'll recommend minimum 11") works perfect for my needs of keeping tabs on two things at once
