Discussion topic: How do I remove UHD?
This message was authored by: kingcreole78
I've rang the phone number but keep getting cut off when I mention I want to cancel UHD. Is there another ay to cancel the UHD pack?
Re: How do I remove UHD?
@kingcreole78
To remove a part of your TV package you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that will appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
