Discussion topic: How can I get a new skyQ remote control?
Message posted on 13 Apr 2026 09:02 PM
Message posted on 13 Apr 2026 09:17 PM
Re: How can I get a new skyQ remote control?
@LainySmith-2_7 wrote:
My granddaughter has damaged my remote control and I am in need of a new one
@LainySmith-2_7 have a look at the link below it should lead to ordering a new one
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Apr 2026 05:06 AM
@LainySmith-2_7
It may be quicker to purchase a new remote from a retailer / larger supermarket.
Meanwhile, if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 14 Apr 2026 07:34 AM
@Daniel0210 wrote:@LainySmith-2_7
Everyday is a school day, I've never needed or used the Sky Go app on the mobile so didn't know that you could use it as a (very) basic remote for the box. Although unless I've missed something obvious, it's beyond weird that there's no volume control.
For anyone checking out that link, it's a little bit out of date as it claims it's for Apple devices with IOS version of 13 or above only. There is an Android version there (and has been for a long while by the looks).
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 14 Apr 2026 09:45 AM
@Me134 wrote:
@Daniel0210 wrote:
@LainySmith-2_7
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?Everyday is a school day, I've never needed or used the Sky Go app on the mobile so didn't know that you could use it as a (very) basic remote for the box. Although unless I've missed something obvious, it's beyond weird that there's no volume control.
No there is no volume control on the Virtual remote.
The volume control on the phyiscal remotes just use IR codes that your TV remotes use - there is no volume control info passed electronic between the SKY box & TV - hence no way for the virtual remote to do this
BTW you are correct that the link is out of date - it was the original announcement when the virtual remote was not available on Andorid and 'the new year' was more than one ! It is now available on both iOS & Android
Message posted on 14 Apr 2026 09:49 AM
Ah, should have thought that through myself.
Not a Sky employee
