Discussion topic: Hot spot
Message posted on 22 Mar 2025 08:09 AM
Hot spot
Hi
i have by problem with Wi-Fi that can't be fixed until Tuesday. I want to connect to via hot spot on my phone. From what I have read you go via settings and get to advance set up. However I have no advance settings on my screen. Any ideas
Message posted on 22 Mar 2025 08:16 AM - last edited: 22 Mar 2025 08:19 AM
Re: Hot spot
Open up settings on your phone and type hotspot, it should take you to the hotspot section, to turn it on.
Message posted on 22 Mar 2025 08:22 AM
Re: Hot spot
i have done all that. It is then trying to connect the tv via my phone hotspot
Message posted on 22 Mar 2025 09:56 AM
Re: Hot spot
If your phone hotspot is turned on @Keith2908 and you want to connect your Q box you need to carry out a Network reset on your Q box and select the phone hotspot for connection.
