Discussion topic: Hot spot
This message was authored by: Keith2908
Hot spot
Hi
i have by problem with Wi-Fi that can't be fixed until Tuesday. I want to connect to via hot spot on my phone. From what I have read you go via settings and get to advance set up. However I have no advance settings on my screen. Any ideas
Re: Hot spot
Open up settings on your phone and type hotspot, it should take you to the hotspot section, to turn it on.
Avatar for Keith2908
Re: Hot spot
i have done all that. It is then trying to connect the tv via my phone hotspot
Re: Hot spot
If your phone hotspot is turned on @Keith2908  and you want to connect your Q box you need to carry out a Network reset on your Q box and select the phone hotspot for connection.
