Discussion topic: Horizontal lines across screen
This message was authored by: Dave244
Horizontal lines across screen but only through q box. Not visible when streaming on Netflix or Prime
TV is Toshiba less than 12 months old.Toshiba had me rin some tests which showed no problems
Would suggest an issue with teh box connection
Have tried different HDMI cables with no change
This message was authored by: Greenfingers001
Re: Horizontal lines across screen
Hi @Dave244 try changing the video output from the SKYQ box to 1080i
Avatar for Dave244
At the risk of seeming stupid, how do i do that please?
@Dave244 @to change the output to 1080p Press Home on your Sky Q remote, then select Settings, followed by Setup. Select Audio visual, then Picture resolution and select the resolution to 1080p
This message was authored by: Addie15
Update-We are closing this chat session now but if there is anything else in the future we can help you with, please do not hesitate to reach out. Thank you.
