Discussion topic: Horizontal line on tv
Message posted on 21 Mar 2023 05:50 PM
I have horizontal line on the tv every few hours. Sometimes it moves up the picture sometimes it stays at the bottom. Changed hdmi and switched tv's but still issue occurs. So frustrating especially when watching live sport. No issue when Netflix or youtube playing only with sky tv. Grrrr!!
Message posted on 21 Mar 2023 08:05 PM
Re: Horizontal line on tv
Hi @Dalverlo
Message posted on 21 Mar 2023 08:10 PM
Thank You for your reply.
I have already done this on the phone with sky last year but unfortunately didn't work 😞
Message posted on 21 Mar 2023 08:29 PM
Message posted on 21 Mar 2023 08:35 PM
I watch the football & F1 etc in UHD and that's when it's most frustrating when it happens 🙁
Sky are useless, paying £70+ pm and yet cannot even enjoy the service fully.
The sky box freezes in the morning every couple of days too so in the mornings I have to unplug & restart the box. Sooo frustrating!
