Discussion topic: Home move
This message was authored by: purplepuggy
Home move
Have been trying to book a home move on my sky which always worked fine but doesn't appear to be working
is there a contact number or email address instead
It always used to be so easy in my sky app
Re: Home move
@purplepuggy
Have you tried the website:
https://www.sky.com/moving-home
Avatar for purplepuggy
Re: Home move
Tried the link just goes straight to thank you for booking your home move without adding any details about the move
have tried clicking on all the home move links and all the same
Re: Home move
@purplepuggy
If that continues then you'll need to contact Sky.
These are the current methods for contacting Sky, and some will be more appropriate than others for your particular situation …
🟢 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟢online help via this link
https://www.sky.com/help
🟢Sky Assistant 💬 should also be available via
🟢Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟡Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed at a weekend.
