Discussion topic: Hi
This message was authored by: Harjindar
Hi
Hi
My sky tv having no satellite signal
Re: Hi
@Harjindar
If a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you’ll need to liaise with your landlord or building management company who deal directly with their approved engineers.
Avatar for Harjindar
Level 0 icon
Re: Hi
Re: Hi
@Harjindar
Yes. My first reply still applies.
