Discussion topic: Hi , I have just moved and do not have blue areal cable as it was secured at previous address
This message was authored by: Emilybest18
Hi I have just moved and fo not gave blue areal cables in bew address as they were secured in previous address
Re: Hi , I have just moved and do not have blue areal cable as it was secured at previous address
Hi
The colour isn't really relevant, they probably just used different colours (in a flat I assume?) to differentiate terrestrial from satellite or cable incoming signals. It's what they're connected to at the other end that matters.
If you have SkyQ, you should have contacted the house move team at Sky to get you the right hardware needed at the new property (and move over your billing etc details) - I would contact them now.
Hi @Emilybest18
If you have Sky Q it's best to book home move through Sky
https://www.sky.com/help/articles/home-move-start
