Discussion topic: Hi I have just had sky q fitted and had logged into paramount plus.
Message posted on 29 Jul 2023 04:53 PM
The app is now missing from the main box. I have tried app refresh and also software update to no avail. This is really annoying. Any help would be greatly appreciated. If I go into shop and try to add it again it just says I have already paired my sky account with it.
Message posted on 29 Jul 2023 05:41 PM
Re: Hi I have just had sky q fitted and had logged into paramount plus.
@22Carolyn22 it can take up to 24 hours for an app refrewsh to work although it rarely takes that long.
I dont know how long you have given it but leave it an hour then try a reboot ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
