Discussion topic: Help
This message was authored by: Hutchys66
Help
Hi how can I get help with my sky box ? It's not starting up when try to watch tv?
Re: Help
Hi @Hutchys66
Try rebooting your Q box.
note: some features may take up to 5 minutes to return..
If Q box come on and the remote control does not function,
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
