Discussion topic: Router not connecting to tv through wifi
This message was authored by: SueChez
We are unable to use voice control and access Netflix and amazon. Done all the resets as per instructions. TV will not connect to router, although I have broadband WiFi to my computer.
HELP!!!
Re: Router not connecting to tv through wifi
HELP!!!
Hi @SueChez
Have you carried out a Network reset on the Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for SueChez
Thankyiu, but that is what we have already tried,  still no success.
Hi @SueChez
Unless your Main Q box is close enough to your Broadband router to connect by Ethernet then you may need a Q booster to help aid connection.
If on Sky Broadband then you can connect the Q booster by WiFi.
If on 3rd party broadband then you could connect the Q booster by a short Ethernet to your router,   In this case you can connect the Q box to the booster by WPS..
Sky should provide Q boosters FOC to aid Q box connection.
Avatar for SueChez
Thanks. It was working fine last night. I think i will try and get a q booster.
