Discussion topic: Help!
This message was authored by: World+peace
Help!
Hi all, my Sky Q box has an error MR106.
Any suggestions to fix this.
Cheers!
Re: Help!
Cheers!
That's normally a network error on a mini.
Re: Help!
Cheers!
Hi @World+peace Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, do the same with any Mini boxes?
